part identification
Does the XJ40 handbrake (and drum if it uses one) all come as part of the outboard brake caliper and hub from an XJ40?
Greg
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
That's interesting. Thanks for the info. So if I have got this straight now, you can convert to outboard brakes on an HE by fitting a couple of XJ40 hubs, with spacers to allow for the inboard discs' width, and lower fulcrum shaft bushes to allow for the narrower hub casting?
Greg
Greg
Handbrake needs modifying with XJS OB disk parts. There are 2 arms that attach to the inner fulcrum pivots about 40 50cm long and brackets that attach where the calipers would be that hold the cables to the wheels.
The XJ40 has the spaces which Cambridge used, I havent installed it in the car I did install the hubs in the LCAs. To see what was needed. It is possible with a little fabrication for hanbrake.
Hi folks.
The casting number is:
CAC 9483 P
SG 2
I've tried searching the internet for references to that ID and haven't come up with anything. Is there a standard resource that lists these numbers? Or does somebody have a spare that they can look at to confirm?
I don't have a use for the parts. I just hate to send good components to the recycler. Are there enough of these parts available? Should I just scrap them?
Sean
CAC 9483 P
SG 2
Sean
Scott B
10-24-2015 01:29 PM
