Partial voltage at fuses??
Strange issue here. Just replaced the heater core which obviously involves moving things around, though it’s worth mentioning I followed Michael Neal’s method so I did not tear apart the entire interior. Just removed the steering column and unplugged things in the way.
Everything has been put back together but some fuses under the driver’s kick panel are only getting 4-5V with the engine on. Engine off it’s between 0.2 - 0.8V. I haven’t checked every fuse but most of them are this way, but I can confirm the one that sends power to the door locks works fine.
A couple months back I had an issue with the fuses and successfully performed the fix for the fuses that involves wedging small pieces of rubber between the copper prongs so I can confirm the copper prongs are tight.
Any ideas how so many fuses (but not all) can receive partial voltage? Never heard of such a thing. The ones that aren’t acting up are reading the full 12.48V so not the battery.
leep123 (01-15-2022)
IF, these fuses are Ign ON powered, then I suspect the Ignition Switch Electrical Section is the culprit.
Getting VERY common now as age creeps in.
Easily removed, dismantled, cleaned, and refitted.
I have a PDF on this and will add to this post when more time is available.
PDF attached as promised. 9PM Adelaide time.
The following 5 users liked this post by Grant Francis:
Doug (01-14-2022),
Greg in France (01-14-2022),
leep123 (01-15-2022),
MrAndersonGCC (01-14-2022),
orangeblossom (01-14-2022)
The following 2 users liked this post by Greg in France:
Grant Francis (01-14-2022),
JayJagJay (01-14-2022)
Jay - yes they were all performing properly before the work.
Greg - that was my initial thought as well; I guess I was hoping someone might provide a simple one shot solution I had overlooked (some almighty fuse or something). Though to his credit, Grant might’ve.
Was under the driver kick panel testing voltage on the back of the ignition switch when suddenly the wiper started working. What do you know, the ignition protection relay is sort of faulty…I bumped it with my head and that completed the connection.
Had to share this in video form:
The following 2 users liked this post by MrAndersonGCC:
Doug (01-14-2022),
Unfortunately while replacing the ignition protection relay yielded 12V to the fuses that were at 0, the horn still doesn’t work. Here’s the weird part:
Pins 85, 86, and 87 are supposed to have 12V with the ignition on. I get 12V at 85 and 86 but about half that at 87 (like 5.4 or something).
Bad relay, right?
I‘ve tried four different ones and same thing on all of them.
How is this possible? I thought maybe a bad ground but I’ve gone so far as to connect the purple steering column ground wire to the engine grounding strap and no difference.
Any ideas?
Bad relay, right?
Any ideas?
Received 10,872 Likes
86 = 12v with key on
30 = 12v constant
87 = 12v output to horn
85 = ground/trigger
So you wouldn't have 12v at 87 unless the relay was triggered. And if you don't have a full 12v on 30 then you'll never have a full 12v on 87
Does 85 go to ground when you press the horn button?
Greg in France (01-16-2022)
Not sure what year you have but 80s vintage horn relays...and perhaps later...were wired like this:
30 = 12v constant
85 = ground/trigger
30 = 12v constant
85 = ground/trigger
Originally Posted by Doug;[url=tel:2486063
2486063[/url]]In that case, lack of supply voltage to 30, I agree to look upstream at the source....the fuse. Most likely some corrosion at the fuse
On a side note, I discovered that you better not use anodized screws in the back of the steering wheel to hold in the horn pad; they do not carry current so you have to use “normal” steel screws.
These cars are hilarious.
Doug (01-16-2022),
Depends how far upstream you go and what tributary you take
Voltage to 86 comes from a a different fuse, via (from memory) the protection relay then to a fuse. Voltage for 30 comes from the main "+" junction post on the firewall then on to a fuse
pbuhler13
02-01-2019 07:40 AM
