Passenger door foot dome light will not turn off
Old 09-01-2016, 09:51 PM
Michellehmcclure's Avatar
Default Passenger door foot dome light will not turn off
I have a 91 xjs and the light on the passenger side door turned on and won't turn off. Any idea what is wrong?
Old 09-02-2016, 02:42 AM
malc4d's Avatar
Have you a switch on the dash ?
Old 09-02-2016, 05:52 AM
Paul_59's Avatar
Banned
Door light switch contacts can be cleaned with contact cleaner spray or fine Emery paper
If you mean this light it's controlled by a switch at the front of the door.
When the door closes it pushes the switch in, switching light off.
Sometimes a sticking switch can be rectified by pushing switch in and out with your hand.
Old 09-02-2016, 05:58 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
Both door lights are commoned so either door switch will switch on both lights.
The lights are switched on by the switch shorting the Purple/White wire to ground. If this wire was shorted both lights should be on.
If you pull the light out of the door check the P/W wire it may be broken, or the terminal pulled out of the plug and shorting to the door frame.
altownsend
01-20-2018 10:43 AM
andy.buxtonxf
04-21-2016 11:44 AM
Michael Wittmann
03-29-2016 05:16 PM
Michael Wittmann
03-27-2016 07:45 PM
11-05-2006 12:00 PM
Quick Reply: Passenger door foot dome light will not turn off
