Passenger window/door seal damaged
Received 10,872 Likes
I can't tell what part you are specifing in your photo. But, if it's the seals that go on the body around the door entry, no, you don't have to take anything off other than the old seals.
Putting the new seal on is tedious at first, but if you have some sort of a plastic tool that won't dig into the door seal material, that will help.
Removing the old seal is easy, just grab it and pull.
I replaced mine about 3 months ago...job is 90 minutes tops at a leisurely pace.
Thanks,
John
1987 XJ-S V12
70,000 miles
Thanks,
John
1987 XJ-S V12
70,000 miles
[QUOTE=J_C_R;1948596]I can't tell what part you are specifing in your photo. But, if it's the seals that go on the body around the door entry, no, you don't have to take anything off other than the old seals.
Yes...it is the seal that protects water from getting down into the door and it “wipes” water off as you put the in down down.
WTB[Western US]: XK8 98 Quarter Window Waist Seal- Passenger Side
XJsc-guy
05-23-2017 02:46 PM
matl
07-16-2008 12:12 PM
