PDU Detected a ton of issues when attempting to reorient sensors
I recently replaced my TPS and successfully reset it using my recently acquired PDU...however when attempting to reorient the oxygen sensors...just because I was there, the PDU kicked out the following issues:
GH009-12 Pin 12 : Male (W/R) - Brings Ignition Power to the Transmission Relay (FIG.26)
GH009 : 16-way Sumitomo (B) - Brings Ignition Power to the Transmission Relay (FIG.26)
GH009 next screen - Brings Ignition Power to the Transmission Relay (FIG.26)
LB291-86 Pin 86 : Female (W/R) - Ignition Power to EMS Power Relay (FIG.25)
LB291: Relay (W) - EMS Power Relay (FIG.25)
LB212-1 Pin 1 : Female (W/P) - Power from Fuse 7 on Right Fuse Panel to Inertia Switch (FIG.2)
LB212 : 3-way Econoseal III - Power from Fuse 7 on Right Fuse Panel to Inertia Switch (FIG.2)
PF007-2 Pin 2 : Male (W) - EMS Power Relay ; Transmission Relay
PFBOX ; 22-way Rists fusebox PF007 : Individual Fuse (O) - - EMS Power Relay ; Transmission Relay
No power to Circuit - Select PASSENGER FUSEBOX FUSE 7 from POWERFEEDS menu to continue diagnosis
I guess I have to start poking around...
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/192x256/img_7484_1__0253463e0589124c934d26ee6bc991cf546b3419.jpg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/192x256/img_7483_1__c331161e98c0c965bd1f5c4498b2ff29f15e5e16.jpg)
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/192x256/img_7485_1__338d19bdc0819cab888eeae4f988eb4fb0b4a722.jpg)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/192x256/img_7486_1__5b98e9c4d231a8a54eaa53b3da745147e9e0c69e.jpg)
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/192x256/img_7488_1__77cd210e0872cadf711c3866b1d58a48822c4be9.jpg)
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/192x256/img_7490_1__157c7881ab9036263102a7a89b68f3fa2ee481d3.jpg)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/192x256/img_7491_1__007bf59901825fc577ab1f54f3a200b6cdaa9961.jpg)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/192x256/img_7492_1__a9f598f91a1973d22393dffee1827a08e9157694.jpg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/192x256/img_7493_1__62ee02b24e3fe1a62a28bdc641673b5e4081dcbc.jpg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/192x256/img_7494_1__f1f0f4123a0a26d7219fcc86dfac05b7fe63b672.jpg)
Here are the pictures in a larger size
No power to circuit - Select PASSENGER FUSEBOX FUSE 7 from POWERFEEDS menu to continue diagnosis
I don't have all of the PDU cables, but I guess I should grab the multimeter...
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/960x1280/img_7483_81c6cf2b73ac411a0bfdb8fbb49c6e05874ded80.jpg)
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/960x1280/img_7484_fb33e1b595ac353e0f3e649b943d88e15294e19b.jpg)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/960x1280/img_7485_efdccb2cf541276c8b5e0db9c2f6db9c19731e5a.jpg)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/960x1280/img_7486_21b3b0d3e11619e3c9923003abdb8b9916af46d0.jpg)
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/960x1280/img_7489_f452017308bc95a0584209c830d5309d90ae2838.jpg)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/960x1280/img_7490_52c6aa20b346e734fee67735fbc7b25cecef682e.jpg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/960x1280/img_7491_6ee0ff084f88357bdecc00ece9dcfb6b21cbee8a.jpg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/960x1280/img_7492_c6b9e0ab4dc32d6711c130b807b91aa6aa40168f.jpg)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/960x1280/img_7493_deb3e24b315659ef9a3690c4ddaa2d2064a66762.jpg)
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/960x1280/img_7494_943fe32ce9e48b6830241eff1c02eb0a03d93114.jpg)
vdpnyc
05-10-2016 01:04 PM
Gameblaster1
04-25-2011 11:45 AM
jag79
21
11-17-2010 09:29 AM
