In order to get this pic to open upside down I went into my pics rotated it but in order for it to post upside down I had to restart the computer before it would take effect, so I think that is your problem becaues I rotated the pic upside down clicked on it to insert and it still came up right side up, just restart first.
Wherever your pics are coming from rotate before posting.
Upside down? Stuff and nonsense! Here, look at my map of the world for proof.... A True Mappe of the Worlde, Shewing the Most Important Kingdoms and Nations on Toppe....
Thou art correct. The idea that this planet has a top and a bottom is something European astronomers made up. The universe has no top or bottom.
I just tried out your Super duper method of uploading Pics on my 'Cherry Blossom' restoration thread and found there are a lot of ways in which it's so much better
Than uploading with the 'Yellow Envelope' 'Thingy'
And while it's maybe not so quick, at least you can edit your Pics there if you need to
Ron--how are you uploading photos? What steps are you using? When I hover over one, the link reads "https://www.jaguarforums.com/forum/attachments/xjs-x27-32/207004d1512948363-pic-test-20171129_114010.jpg".
What do you do to get that? I'm going to test attaching a link to a photo. https://i2-prod.birminghammail.co.uk...jaguar-XJS.jpg
Hm. It only shows up as a text link.
Unless we know what steps you are using, we can't tell where you're going wrong. The only other reason I can think of is that your camera EXIF data is screwed up, and your camera thought you were holding it the other way around or something. I assume all these images show normal orientation on whatever program you use to view them normally, however.
could be camera or me.
JF says pix to large ,to many pixels, need i try to readjust camera, size numbers dont go low enough, ? all pix from are from my photo albums Samsung android 2.4M smallest # , with another camera Nikon pix #s go down to 50K, but pic resolution is terrible, but they go thru great OK.
