pickup coil
Old 06-11-2012, 10:32 PM
Doug's Avatar
Received 10,888 Likes on 7,158 Posts
If it helps I found some notes from my Mustang TPS installation. Apparently the TPS terminals were marked A B C
My handrwriten notes say....
Green C 5v power
Yellow A Throttle pot ground
Red B Output to ECM
Of course the "ground" doesn't mean an external chassis ground
<shrug>
  #102
Old 06-12-2012, 01:31 AM
Greg in France's Avatar
Received 9,280 Likes on 5,452 Posts
Green C 5v power
Red B Output to ECM
<shrug>
I believe, Doug, M90, that 'ground' refers to the return to pin 19, as in my previous post:
"Tpot output non-wiper (ie after the 5v has gone through the resistance, but not including the wiper output) goes to pin 19
CTS output (ie after the 5v has gone through the resistance of the sensor) also goes to pin 19"
Greg
  #103
Old 06-12-2012, 07:55 AM
Doug's Avatar
Right.
"Throttle pot ground signal" is what my schematic says, at pin 19.
  #104
Old 06-17-2012, 02:22 PM
M90power's Avatar
an OEM bournes TPS allowed it to run slightly leaner, but other than that there was no difference. it ran much better with the CTS unplugged.
  #105
Old 06-17-2012, 03:43 PM
M90power's Avatar
My catalytic converters can be eliminated as a suspect, as theyre empty. i had to hack up my exhaust to find out. Xp
tlynch
12-31-2020 01:58 PM
SD96XJ6L
11-05-2015 10:47 AM
Socal_transplant
10-01-2015 01:15 AM
Bcrary3
09-27-2015 12:21 PM
Quick Reply: pickup coil
