Pictures of the NEW V12..... yep.
#61
Looks like a nice car. have fun driving it home. Is it Solent blue JFJ ?
Yes I know its an old car but I have just noticed that the rubber rooflock locating pin is missing from the top of the windscreen post. I believe that parts bcc 5578 and 79 are no longer available. They sometimes come up on Ebay. Also the window rubber seems to be hanging out. It looks like the ski slope has been recovered in black vinyl or painted.
#62
Malc... yes will need to sort that rubber.
Another picture recieved today, car paid for just waiting for me to collect.
How many weeks.... do I have to wait... 6 weeks ahhhh
$13,800 USD. The NZ dollar has dropped. $21,000 NZD Have I said I am very pleased. Owner has said if I find rust other that that small spot, which he had not noticed and would have had it repaired.. he will refund my money!
#63
#65
Might as well keep this post running, I really enjoyed OB's post, individual question will be asked on separate site then added here.
Nice for a new bee to join my progress.
Next up is a car lift, nearly finished rebuilding a classic bike (4yrs) first job was build a bike stand that went up and down.
So plan is to do the same, I have found some plans and are in the progress of buying them. I could build them without from pictures but for 26pounds its worth getting them, know what strength steel to use, and not guess.
This is what I have planned. Nice and save for my skinny butt not to getting squashed.
I like the rear supports... so i will build them also. This set sold for 600 pounds second hand. I will build this for... who know time will tell but I can get SOME steel for free..work. Oh and I can weld which helps.
#66
#67
Best part is it all comes a part and will lay flat under the car, stands will go under the house until needed.
Here is a pic of the bike stand I built some years ago, car lift will use the same jack.
Bike lift could do with a clean... but you get the idea. Bike lift goes down to about 200mm and higher than I have needed.
#68
#69
So I am working on my new car ramps...needed some dimensions to get it right, read about people being squashed under cars and, thats not going to be me.
While off topic this is about my journey of owning an XJS..(still 4 weeks away) I want to safety get under the car.
I like OB's approach, spend money wisely, just for the chequer plate, cut to size $800. not paying that, so tomorrow I am getting (not sure what) but standard plate cut to length for bugger all, a mates friend (owns a large sheet metal company) felt sorry for me. $360 for the plate and $460 to cut it! Really. So tomorrow I'm getting plate cut not sure what I will end up with but no tread is ok, after all I'm not doing burnout on it. but if its cheap I am in. Wait for the update..
Free is good but less than $360 cut is a bargain.
#70
I have to thank Greg in France for the dimension, really appreciated..
Without this assume forum I would have been to scared to by an XJS.. let along a V12.
My friends just look at me sideways, and say... really a XJS-V12 - were is your bowler hat.. old mans car!.. I am 48.. only 80 year old own these cars!
Looser...! I think not! (some say cool) but not for me.... Mustangs, Valiants , Fords etc, Fact is they do not know what a screwdriver is or the difference between Phillips and Pozi drive.
There has never been more info on the net to fix stuff, and less people can do it...DIY is not cool, just replace! or buy new . My old boss said to me when I worked on machines whats wrong with it, I would say its stuffed and i need a new one. His answer was, ring me when you know what wrong with it... (short story pull it a part and find out WHATS wrong) I used to think AHole... but so true. Few can do it now.
The following 2 users liked this post by Dukejag:
Greg in France (08-31-2018),
orangeblossom (08-31-2018)
#72
#74
Rob... how cool .. head in hands if i had looked at your details I would have known. Shame!
Just getting to know this forum. So we are 30km apart.. LOL
Look forward to meeting, what do you own? New to the is Jag thing so way open to lots of advice and help.
Worked out the current owner has deep pockets and just pays, does not do any work himself. But happy to pay which is great.. (time will tell)
The car has the deeded yellow fan, for $255 NZ I can get a Viscus clutch and black fan, thinking of buying them and courier it to the PO in CHCH and changing it before I drive 1200km home.
I will worry if i do not.... no idea the cost of a fan blade through the bonnet and taken out radiator.. plus.. but my estimations are huge $$$.
Car details...
Here is the link for US spec cars….. Yes a left to right convert from original owner, looks like I will be owner 4.
Vin SAJNV4843KC156137
From the net… and I have highlighted where appropriate.
1st-3rd Position -- Manufacturers Code
SAJ=Jaguar, United Kingdom
4th Position -- Model Line
A=XJ6
A=Vanden Plas
C=Sovereign
F=XJ6
H=XJ6, Sovereign
K=Vanden Plas
M=Majestic
M=XJ12
N=XJ-S/XJSC
P=XJR/Sport
S=Jagsport
T=Rouge/Classic
5th Position -- Class/Restraint
A=Passive Seat Belt (87-89)
T=Driver Air Bag w/Passive belt
V=Active Seat Belt
W=Driver Air Bag (90-95)
X=Driver & Pass Airbag
Y=North American Spec (83-87)
Y=Passive Seat Belt (89-93)
6th Position -- Body Style
1=4 door sedan
2=2+2 Convertible
3=2 door Cabriolet
4=Convertible
5=2 door coupe
7th Position -- Engine Code
0=5.3l 12 cyl, Calif.
1=4.0l 6 cyl, Supercharged
4l 6 cyl, Calif.
3=4.2l 6 cyl
3=6.0l
5=3.6l 6 cyl low compression
6=3.6l 6 cyl high compression
7=4.0l 6 cyl
8=5.3l 12 cyl
9=4.0l 6 cyl
8th Position - Transmission & Steering
4=Automatic (LHS)
8=Manual (LHS)
9th Position - Check Digit
3- means nothing
10th Position - MODEL YEAR
D=1983
E=1984
F=1985
G=1986
H=1987
J=1988
K=1989
L=1990
M=1991
N=1992
P=1993
R=1994
S=1995
11th Position - Assembly Plant
C=Browns Lane, England
12th-17th Position - Production Sequence Number
156,137
I have good hopes for the aircon..
From the POwner
As you can see from the exhaust tunnels there is no problem there and the floors are only surface due to getting wet when i leave the roof down plus in the early days the heater/Aircon did not work $4,000 later and leak testing in dark rooms its fixed. It provides heat and cool, but the noise from the fan if its on anything other than the first position is noisy
Car details...
A=XJ6
A=Vanden Plas
C=Sovereign
F=XJ6
H=XJ6, Sovereign
K=Vanden Plas
M=Majestic
M=XJ12
N=XJ-S/XJSC
P=XJR/Sport
S=Jagsport
T=Rouge/Classic
V=Active Seat Belt
1=4 door sedan
2=2+2 Convertible
3=2 door Cabriolet
4=Convertible
5=2 door coupe
4l 6 cyl, Calif.
3=4.2l 6 cyl
3=6.0l
7=4.0l 6 cyl
8=5.3l 12 cyl
9=4.0l 6 cyl
4=Automatic (LHS)
8=Manual (LHS)
3- means nothing
D=1983
E=1984
F=1985
G=1986
H=1987
J=1988
K=1989
L=1990
M=1991
N=1992
P=1993
R=1994
S=1995
156,137
From the POwner
#75
Bugger I wanted to edit my previous post to add these dimensions, but not possible.
Sorry was a bit lazy and should have done this sooner.
Thanks Greg..
X = (width of tyre+ rim)/2 I presume you mean? If so X = 13 inches
Y = rear overhang from tyre centre = 49 inches
Z you do not give enough data for AFAICS.
V = front overhang from tyre centre = 36 inches
I got quoted $400 for the plate and $400 to guillotine.. really. for chequer plate, I looked and I was not wearing a bra... my head is bald..... rip off@. Not paying that so I looked around and got a mate to go though a mate and bingo.... 3mm (same just not chequer) mild steel plate cut to size $200.
So good to go, Ordered 2 x 9m lengths of 60 x 60 x 6 angle for the edges.
Pictures as I go. not to many as this is a Jag site not a ramp build site! Long story short my ramps are under way!
Thanks Greg..
BuellBiker86
11-29-2010 04:34 PM
