Pink insulation coming from vents
The following 2 users liked this post by VancouverXJ6:
Doug (09-15-2019),
Josh Knight (09-17-2019)
Ha! looks like what my yard squirrel did to my truck's Turbo blanket, can't fault her though it was quite a comfy blanket she tore up. I'd suggest a shop-vac to suck the crap out as much as possible, you may get a face full of insulation for awhile until it clears the system.
If that was my car I'd be investigating HOW the critter got in there at all, I'm having a hard time imagining unless your drainage pipes are missing? Rodent damage is not uncommon particularly with cars that sit outside or were neglected.
To put this in perspective. There’s a “crawl space” under that panel beside the air inlet grill. I filled a garbage bag full of nest buried deep in there. I kinda wish I had found a mouse though, still worried it’s lurking around in there. Also have no idea how much went down into the ducting, or if there’s more nest down inside the ducting. This car was in storage for a while. I’m considering buying an endoscope.
nikmott
05-07-2014 05:18 PM
