Pirelli P600
I just Googled "235/60x15 tires" and there are a number of choices out there for about $100-$200 each. BF Goodrich, Hankook, and some Brand-X choices.
None of them are high speed rated tires, which might not be a concern for you. They're rather conventional tires dressed-up to look like a high performance tire. That doesn't mean they're bad tires and if you're a gentle driver most any of them would be OK, I reckon.
Others will chime in with specific experiences, I'm sure
Mguar (12-01-2023)
I decided to go with the Hankook tires through Amazon at $453 delivered I thought that was a pretty good deal.
Actually, it is illegal for a "business" to put on lower rated tires, but a lot of people don't follow the law here.
If a customer insists on it, we make a note of the speed and load rating on the repair order, and we make them sign a waiver acknowledging it.
It's a shame that the US and European tire makers discontinue them and force people to go to Chinese/Korean and/or lower speed/load rated tires just to keep the car on the road. Goodyear, Michelin, Pirelli and a bunch of others are big offenders.
Greg in France (12-01-2023)
The following 3 users liked this post by Doug:
Which is the reason for lumpy tickover in most cases! The problem over here is that speed limits are so low and so heavily enforced it is more and more difficult to give my car decent excerise!
Doug (12-01-2023)
235/60/15 seem not to be available in the UK. One well respected classic tyre specialist recommends Pirelli 205/70/15 as a replacement for the XJS but they are £323 each. Would be interesting to hear if anyone has tried this size.
There is the option of swapping to 16 inch rims as recommended on another thread on here. There is a lot of tyre choice (225/55/16) and at a much lower price. Unfortunately that means buying a set of second-hand 16 inch Jaguar rims and (of course!) these are way more expensive than 15 inch rims.
Let us know how you get on with the tyres.
Cheers,
LeeP
I think this was the original XJS size, my 15 inch starfish, when I had them on the car, used this size. I swapped to 16 inch because they were either NLA or, as you indicate, idiotically expensive. FWIW, the ride on the XJS is unbeatable on this tyre size, IMO. High speed stability is noticeably better on the 16 inch tyres and rims (although not at all bad on the 15s) but the ride is, while pefectly fine, not quite up to the magic carpet ride the original tyres give.
orangeblossom (12-01-2023)
OB,
As a comparison between 235/60 tyres on a 15" rim, and 225/55 tyres on a 16" rim:
The 16" option will have a fractionally lower circumference. My rough calculations indicate that the 16" circumference would be 94.397% of the 15" circumference.
So, (again roughly!) the 16" option will mean that you are travelling slower than the speedo indicates.
At indicated 30mph, you're doing 28.32mph
At indicated 40mph, you're doing 37.76mph
At indicated 50mph, you're doing 47.20mph
So, you should be safer from getting caught speeding, if you just go by the speedo figure!
Paul
Paul
