Please help identify few vacuum lines
Hi forum, can you please help me identify 2 vacuum lines on my xjs 1992, v12 HE with marelli
so the first one is where yellow nozzle is , it was just like that, without any line
And the second one , is where black vacuum line with orange stripe, it goes to nowhere б just blocked at end
So yes, its 1992, its HE, and yes its facelift, but no, its not the one with 6 litre engine.
Hope this makes it clear)
Mouserider, Ah that explains it! Although they have the same basic engine, the facelift cars are not referred to, or badged, as HE because its a fundamentally different car with many other differences. So it's just known as a 5.3 facelift.
The item in your pic seems to be a cruise control pump, I think. Unless someone else chimes in, I'll look up the orientation of the vacuum pipes. Or you can just look at the diagram on Jaguar's parts website and it will probably explain it.
Paul
Paul
Paul
Paul
Thanks for the tip, i guess you referring to 2nd pic with black and orange line, but what about first one, which is not connected at all?
Don't know about the first one.
Hard to tell exactly with the photos so zoomed in, but, if in the second picture the holes I circled are for the coolant expansion tank then you are possibly looking at the vacuum line running to the charcoal canister located behind the forward LH wheel well panel.
It would help to see both ends of the vac line, rather than a centre section.
Mouserider,
Can you take a better photo of the CC pump so we can better see those pipe fittings? Also is the pipe from teh dump valve connected to the pump? I can't see clearly in that photo.
Have you looked at the Jaguar parts website diagram to see the pipe connections?
:Paul
:Paul
