Plug gap 5.3
OK y'all (southern for you all). Today I decided to change plugs in my Truck and my 92 XJS. Truck is 35 thousandths, XJS is supposed to be 25 thousandths. So I merrily changed the plugs in the truck, then like a simpleton, set the plugs in the XJS at 35 thousandths, and buttoned everything back up. It seems to run fine. And since it is an unbelievable chore changing the plugs.....should I pull it back down and drop the gap, or will it be OK with the wider gap? Put Autolite iridiums in it for what it is worth.
