Is this the power steering fluid cap?
Sorry for a remedial question: is this the power steering fluid cap on my '84 XJS? I've just inherited this car and am obviously learning the basics, and enjoying the learning so far. I can't find a good fluid-location diagram online, it's not in the manual, and the cap isn't labeled.
I have some smoke that seems to be coming off the cat, and a fluid leak. Others on this forum seem to think it's a power steering fluid leak. I did take a look, and this thing is indeed bone dry, so it would confirm suspicions. Before I add anything, can someone please confirm this is the power steering? If so, are there common leak sources? It was topped-off when I had an oil change, 500 miles ago, so a pretty fast leak. Also there's a new groan when I turn the wheel. Dexron II or III have been recommended - particular brands recommended or whatever AutoZone has?
Thanks a lot in advance for the help.
Received 10,979 Likes
