power steering leak (vid in thread)
EDIT: I've decided to replace with rebuilt steering rack
hi forum,
I'm a fairly new member (introduction here) and have my first issue.. a power steering leak on the LH side..
I felt the steering start to feel tight a week or so ago, and then one day leaving the store, it was like it was empty, with all of the bad associated noise. I took it to the auto store on my way home (just a few miles) and picked up a bottle of Valvoline full synthetic ATF, as they didn't have Dex III available. It said compatible with Dex IV, and I've read that these are backwards compatible, so I went ahead and went with it.. I filled it up, and it drove fine, but then I noticed leaking. (there was no evidence of a leak before, but it could have been hiding in the area I park. just never noticed anything) I got it up on stands and tracked down the leak (vid below) this seems to be the only leak location.
I'm doing parts/repair research now, but if any members know any tips about these repairs, I would be greatly appreciative.
hi forum,
I'm thinking it might the pinion seal after some reading and watching
from the living with a classic series.
my question is what else should I replace while I have everything out.. wishbone bushings look rough so I will probably replace those along with the rack bushings.
anything else I should prepare for parts and tools wise? I'm a shade tree mechanic, but I grew up in welding and fabrication and am no stranger to turning a wrench and working in tight spaces.
There is probably mostly Lucas in the PS system now and it over the course of a few months slowed the leak considerably.
Not stopped, nothing is going to do that, but it's slowed enough I can check the fluid level once a week or two and live with it
till I get around to rebuilding the front suspension rather than making a special trip in there just to do the rack.
Wasn't an overnight cure and I suspect it's a coin toss whether it helps a given example or not but it did in my case.
MAVAL in Ohio
I don't have the receipt but I do have the shipping information for Maval:
Maval Manufacturing
Attention: Dale Lumby
1555 Enterprise Parkway
Twinsburg, OH 44887-2239
They did right by me. It's 10 years ago and things can change, but I'd check them out before going the new route.
appreciate the reply..
I called Maval a few days ago.. around $600 for a rebuild and 72 hr turnaround, if I remember correctly.
I don't love the idea of shipping it off, but it does seem like a solid option.
I also found what seems to be a a solid oem ZF rebuilt one on eBay for around $500.
still trying to determine what else I would need for the conversion.
jaguarrick1
06-26-2020 03:47 PM
al_roethlisberger
10-11-2014 08:12 PM
