Power window won't go up
Rafal (07-02-2016)
Received 10,881 Likes
If you put your vehicle details in your signature model and year will help the tech guys tailor responses for your car, there a a couple of different setups, are your switches in a plastic faceplate or directly into the console?
Being a 92 your switches should be in a bezel, these have tabs on the left and right sides, be careful when you pry them out as they break easy, don't ask, as the plastic becomes brittle over time.
Once out you can remove the switches from the bezel, but before doing this swap the connectors to verify the switch is the problem.
Rafal (07-03-2016)
I think the best tip to remove the bezel starts off with ordering a new bezel. They were NLA for a long time, but are now available again.
I think you'll have to remove the armrest cubbyhole to get to the one screw that keeps the ski slope in place. One the screw is removed, you can angle the ski slope up and stick your hand underneath to ease out the switch assembly, including the ability to disconnect each switch from the harness.
warrjon (07-03-2016)
teroks
10-02-2022 04:38 PM
springer
04-22-2016 11:05 AM
