Power Windows on an 84
So, my drivers side window decided to not go back up after it went down. I decided to see what was going on and found that the window motor is only turning one way. Is this normal? Should'nt the motor be spinning both ways? If so, does this mean I need a new motor?
Thanks!
Thanks!
Received 10,920 Likes
Thanks for your help.
Use aerosol electrical contact cleaner. You local auto parts store will have some.
It's been quite a long time since I removed an window switch from an XJS. As I recall the *correct* way is to lift the ski slope (console woodgrain panel) so the switch can be released and pushed out from behind. However, I also have a vague memory of siply being able to wriggle the switch out from topside.
Others will chime in.
99xk8guy
06-05-2023 06:28 AM
1964Daimler
09-09-2015 11:28 AM
