Power Windows AGAIN!!!
Hi Folks,
As per usual, it's very hot out, so my windows won't go down. I think you know what they do when it's freezing out. First the pass side now the driver (LHD). I cannot locate the window relay or the thermal cutout. I can find the ignition load relay, something I have suspected giving problems before, because on several occasions I could cycle the ignition on/off, and the windows would come back to life. Not this time. My diagram says pink/white, brown/blue (2) and black for the window relay. I've looked everywhere. Any tips?
Thanks,
Seann
Thanks,
Seann
Received 10,920 Likes
OK, dropped the dash after comment "farther to right" (for looking for relay/cutout) and found the thermal cutout. Plugged in a 20 amp fuse in it's place and the driver window works. Also found the spring clip for the original "round" relay...this one has been replace with a square unit. Tried switching the blue/brown wires (left to right?) but no change still just driver side operating. Window switches are both new.
