Powerlock manual
Powerlock manual
Hello all.
I'm new to this forum and need some help.
I have a 3.54 powerlock xjs diff that I want to rebuild.
Can anyone tell me where I can get a manual from please.
the unit is not going into a jag by the way.
I am a very competent mechanic with full workshop facilities.
many thanks in advance.
Len
Len
The Jaguar service manuals are quite good. Here is a link to one at the start of the section. In Jaguar speak , you're rebuilding the "Final Drive"
Service Manual AKM9135 Ed.4 (1990) p51-1(m)
You will need shims that go between the carrier and case, and a special bearing puller and press. The bearings will need to go on and off several times to get the shimpack correct.
I rebuilt mine this spring and it went well following the manual and being precise about the tolerances and clearances. Be slow and methodical and it will turn out well.
xjsv12 (10-31-2017)
