pre face lift projection headlights? 1988
I just did a beautiful conversion on a 69 firebird with hid projection headlights has anyone done this too their xjs?!? I can picture how amazing it would look properly done and the dream has me drooling at night. Any idea what size the housing is? Or do I have too pull it out of storage and make my own measurements
It'd be nice to be able to work with somebody at the drafting board to try and see what can be done and how it would look. I do know that it'll look smarter, if not more modern in a similar fashion as when comparing some facelift lines to pre facelift cars (please, no offense; the facelift had a purpose that was greatly achieved).
88-xjsv12, is that sets of lights you're looking at accessible in the Internet? Determining which exact light assembly will be used is paramount before even thinking of any body changes. Well, actually the whole conception must be "approved" for use and finalized before touching anything. Hey...I'm drooling, myself, with just the thought...
![Icon Drool](https://www.jaguarforums.com/forum/images/smilies/icon_drool.gif)
I've been looking at several online going too select which style I like then I'll dig into what power levels (volts/amps/watts etc) once that's done I'll pick up a set and get too installing them but this won't be till September . I will update everyone one which lights should be compatible but may need modification too fit and function properly can't just throw them in aiming them is the key too this or it was a waste of time.
This is on my to-do list as well. The stock lights are so-so at best and will need some rewiring (good sized wire for power hooked up to relays) and probably a swap to different units anyway so if I'm going to spend the time and trouble...
Please do keep us posted on what you wind up doing!
update on the headlights Im going too retro fit the headlights with f-xr projectors . The other options are very open need too check the back of the headlight if its glass or plastic. I am replacing the ones in my Jeep grand cherokee so the jaguar will follow. Plastic obivously can be drilled not glass so we might have too buy 5 inch housings that fit and modify from there . Ill keep this thread updated and post pictures when complet of the whole process
FS[NorthEast]: 1988 Jaguar XJS H&E Project in Vermont
somoflange
09-16-2015 10:16 AM
