Pre-Purchase Inspection
Try posting your question in the Midwest section also. Good luck.
US Midwest - Jaguar Forums - Jaguar Enthusiasts Forum
You may want to google for "Kirby Palm xjs help", and look at some of the sections there.
The reality for most of us is that you will not a local wrench willing to work/inspect the scary V12 unless they are an old school jag wrench. Some of the suggestions like checking the compression are probably unrealistic if you're buying the typical deferred maintenance car, given that old V12 wiring is likely to crumble, etc.
Definitely look under the car for rust, especially around the trailing arm, door sills, rocker panels.
Good luck
Good luck
theshortwhiteguy
01-10-2016 05:29 PM
