Preventing the vent leak?
Ive been makin g seperate post for each topic I hope thats ok...
I was wondering what the solution is to prevent leaks coming in through the vent and pooling on the passenger side floor.
Im also wodeering where in Canada ir the US you would recomed getting floor panel replacements
Cost of parts and labour
Vs having only the front quarter part of the floor replaced and the cost of that.
Since the car is an 86, if the price difference isisnt huge, it might be worth doing while under there?
If water is pooling on the floor after rain, then it is coming in through the windscreen rubber, almost certainly. There are two solutions:
- get a tube of bitumastic roof sealer, push the nozzle under the rubber, get it between the rubber and the screen, and go all the way round squirting loads in. Bitumastic sealer is Far better in this application than any silicone type gunk. Once done, white spirit and rags to clean it up. While you are at it, also do the rear screen, but this time between the aperture metal and the seal; or
- Buy a new front screen seal and get a screen place to replace the old seal.
ayishas.xjs (04-16-2022)
Received 10,920 Likes
Personally, I prefer it that way. As opposed to a single thread that goes on for months or years discussing 20-30-50 different repairs/projects/problems
I agree with Greg. I'll just add that an option is to replace the windshield seal.....which in and of itself is rather easy on these cars. Any auto glass shop could do it. Removing and reinstalling the bright metal trim, though, is tricky. Best to do it yourself. The guys at the glass shop probably won't have the patience.
Would the glass place ehave the correct rubber piece needed or would I need to sorce it myself?
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x2000/20220405_145032_37d4a727b8eca0566de7a7bba94e40870d03cd27.jpg)
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x2000/20220405_145032_f74f64abef36e2a63e083ffb4cd98cba1534e641.jpg)
The trim fits into a grove in the windshield gasket. You need to carefully work it in. Get a smooth plastic tool to help, slide it on top of the trim and in the grove, then lever the rubber on top of the trim. Move up a little and repeat.
Looking at that picture, I would not be surprised if you found some rust when you remove the windshield.
Agreed. You really need to have that screen out and a new rubber fitted, having first cleaned up the metal edge and repaired anything that has rusted. You will have to source the windscreen rubber. David Manners, SNG etc should have them. If you ask the local JEC branch, they may well know of a screen place that has experience of doing them.
