programming a new remote
Welcome to the forum rossstein,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to XJS forum. The Advice / Feedback & Suggestion Center is for posts about the forum and not for tech questions.
Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Hi Allan,
My '94 XJS V12 does not have a security switch. Two remotes came with the car but only one works. The other one had a dead battery which I replaced but it still does not work. Do the remotes loose the programing when the battery goes dead? If you know how to program this model, I could try to get it working. Thanks for your time.
Bob (Spillwaybob)
Bob (Spillwaybob)
Hi Allan,
Bob (Spillwaybob)
Bob (Spillwaybob)
Yes Jaguar removed the security switch in the 94MY so you and I are out of luck
The wiring for the switch is still available though, it is under the center console. Here is a link to a thread made by Spikepaga. He links to a video he made showing how to connect the switch. It is easy to do and should get you sorted provided the remote is actually working!!
https://www.jaguarforums.com/forum/x...s-video-85375/
zdrapec
09-25-2015 05:49 AM
