Programming remotes on 94-96 XJS video
Hello guys!!
I made this video on how to program the remotes on a 94-96 XJS with alarm module Dpp 1050 on the US or Dpp 1051 in the UK. I tried to make it a clean as I could but I am not a professional, so please excuse my errors.
Couple of disclosures, I am not responsible for damage to yourself or your vehicle. This is just a video of how I have programmed my car and how many others have done it as well:
The following 3 users liked this post by Spikepaga:
Mark,
Excellent video with good information. Thanks for sharing it with us.
Unfortunately I won't be able to use it on my car as I found out that the remote I was trying to program is not the correct one for my car. I really did not need it but it would have been nice to have a spare "just in case"!
Take care,
Bob (Spillwaybob)
Take care,
Bob (Spillwaybob)
Softball60 (10-24-2021)
Used your video to program my '96 keyless. Worked like a charm after I figured out that the switch I used was a push-button on/off and not on/off per push. Thanks!!!
As for remote compatibility, the one I bought had the following info:
1993 1994 1995 Jaguar XJ6 XJS Fob Remote
G57JTX318
DBC10084 318MHZ
DOC/MOC 1808 K1006
G57JTX318
DBC10084 318MHZ
DOC/MOC 1808 K1006
Disconnecting the battery has nothing to do with programming the remote.
Keep keep trying because it does take multiple times to get it to enter programming mode. You have to do it just right. Based on your model year you should have the switch installed from the factory whereas I had to add mine. Try increasing the number of times you flip the switch each time. Do one extra flip or one less and see if that helps.
BENJ628...You were right on! I increased the flipping of switch to about 10 times (instead of the mentioned 5) and the car went into the program mode. My new replacement FOB now works perfectly. FWIW, I bought it on EBAY for only $13.71 with free shipping. Thanks sincerely for reaching out!
Richard
https://www.ebay.com/itm/401538278137
Richard
Rick25 (07-17-2020)
Hello guys!!
How to program keyless entry remotes on a 94-96 Jaguar XJS - YouTube
stpierrema (11-12-2021)
Try this from the stickies above
Recoding Remote Alarm Transmitters FAQ - Jaguar Forums - Jaguar Enthusiasts Forum
Sirjagelot (03-03-2022)
You can sometimes see them on Ebay. First you must know the frequency of the alarm. I believe that if its not a US import the French used 433 MHZ. If a US car that should be 318 MHZ.
Genuine Security System For Jaguar Xjs Sports Coupe/convertible 1975 - 1996 Classic | Jaguar Land Rover Classic Parts
You have to provide the switch but the wires are there. I am the person who made the video.
