Pulling left when braking
Old 03-12-2021 | 04:45 PM
mghirsch's Avatar
Again, I have seen bad rear calipers cause a pull/\.
Old 03-13-2021 | 12:52 AM
Greg in France's Avatar
Originally Posted by flyingv65
My 1995 XJS Vin # SAJNX2740SC198197 also pulls to the left when braking. It's quite a pull but it doesn't take a lot of effort to hold the steering wheel to keep it straight. I already replaced the front calipers pads and rotors and the system seemed to bleed ok so I am thinking the hoses are ok but maybe you don't see the hose issue when bleeding? I also swapped sides of the front wheels so it's not the tires. From this thread I have noted to check the suspension bushing and rear calipers...and maybe the hoses? Plus possibly, now the valve block. I think one of those is about $1800 if I remember correctly if I have to replace it. Could it be a steering issue? Although it seems to go straight under normal driving when I let go the wheel.
Appreciate any feedback/ on how to best narrow it down other wise I guess i'll replace parts from cheapest to expensive order.
sorry, forgot to say it's 2+2 IL4
Renew the front flexibles, this is a must. Check that the pads are able to move easily into and out of the caliper if you remove the pins, I usually grind down the metal edge of the pad a bit to be sure the pad slides into the caliper easily.
Then post again with the results.
Ian Rattray
05-08-2020 06:54 AM
NTL1991
10-02-2016 02:14 PM
mikelibera
XJ40 ( XJ81 )
09-04-2015 05:17 PM
scrible
10-24-2012 04:03 PM
test point
07-07-2010 08:42 PM
Quick Reply: Pulling left when braking
