Pulling left when braking
My 1995 XJS Vin # SAJNX2740SC198197 also pulls to the left when braking. It's quite a pull but it doesn't take a lot of effort to hold the steering wheel to keep it straight. I already replaced the front calipers pads and rotors and the system seemed to bleed ok so I am thinking the hoses are ok but maybe you don't see the hose issue when bleeding? I also swapped sides of the front wheels so it's not the tires. From this thread I have noted to check the suspension bushing and rear calipers...and maybe the hoses? Plus possibly, now the valve block. I think one of those is about $1800 if I remember correctly if I have to replace it. Could it be a steering issue? Although it seems to go straight under normal driving when I let go the wheel.
Appreciate any feedback/ on how to best narrow it down other wise I guess i'll replace parts from cheapest to expensive order.
sorry, forgot to say it's 2+2 IL4
Then post again with the results.
scrible
10-24-2012 04:03 PM
