Pump Kit convertible
The new seals can be had and the leak is a fairly common issue. I would really have to go digging for the product and will give it a shot, but it can be found in the forum. That, and what needs to happen to replace the seal. Square edged rubber type o ring that can be had for change. Less expensive than the shipping.
About 7/8ths down the first post in this thread. Lots of good info. Then, a possible seal...
https://www.jaguarforums.com/forum/x...ics-fix-71273/
SKF 527935 LDS & Small Bore Seal, R Lip Code, BB Style, Inch, 0.375" Shaft Diameter, 0.625" Bore Diameter, 0.125" Width
The following 3 users liked this post by JayJagJay:
