Push Brake pedal blows fuse & turn signals don't work
I installed a new turn signal arm assembly and plugged into connecter and everything worked fine. I started working on interior lighting and headlamps and now the brake pedal blows the fuse and the turn signals dont work until I install a new fuse and don't stp on the break. Is the brake pedal be pushing on the limit switch and is the limit switch normally open or closed?
Any ideas?
Pat
Any ideas?
Pat
Any ideas?
Pat
Any ideas?
Pat
