put in my new distributor... little help.
Old 08-06-2018, 04:59 PM
944xjs's Avatar
Default put in my new distributor... little help.
I just lined everything up as it came out... went to start it and it started right up but after a few seconds died. Start it up and rev it and return pedal and it dies or atleast sputters terrible. If I hold the throttle at like 1k it runs. If I rev it is sounds and feels way better! I was going to try and do timing as suggested till it sounds “sweet” but it won’t stay idling now. It’s not up to full temp but that shouldn’t effect anything. I guess I might atleast get a base timing with a timing gun but if it won’t idle. The ccv shouldn’t need adjusting after a new distributor should it?
Old 08-06-2018, 05:36 PM
baxtor's Avatar
Received 1,165 Likes on 754 Posts
Car details? If '94 (going by username) and marelli are you sure you have both coil leads attached.
Old 08-06-2018, 06:49 PM
J_C_R's Avatar
I think the concept, presented here by experienced members, of adjusting timing until it sounds "sweet" is a good one, but only if you are close to begin with!
As baxtor said, we need details! Year, engine, why was it necessary to replace the distributor in the first place? Good connection between the coil(s) and the dizzy? By "new" do you mean literally, or "new to you", i.e., out of a junked car? Lucas or Marielli ignition? Was anything else changed, or any other maintenance done at the same time?
Thanks,
John
1987 XJ-S V12
70000 miles
Old 08-06-2018, 08:52 PM
944xjs's Avatar
Thanks,
John
1987 XJ-S V12
70000 miles
sorry, 88’ xjs v12. Lucas distributor out of a junkyard car. Converted to single coil a few months back. Car was running and idling fine just didn’t have the power and feel. The weights/springs inside mine were stretched and basically stuck and the vacuum advance was also toast. I feel like I had it running good for a car that needed love. So now with the proper part and everything working it needs a new tune. Right before I left and it was almost upto temp it was running a tad better and wasn’t stalling.
Old 08-07-2018, 12:34 AM
Jagboi64's Avatar
Received 3,185 Likes on 2,101 Posts
The timing spec is 18 degrees @ 3000 rpm, which works out to just about TDC at 750 rpm.
Old 08-07-2018, 03:35 PM
944xjs's Avatar
if I was one tooth off on installing the distributor would it even run?
Old 08-07-2018, 05:50 PM
JigJag's Avatar
I cant recall for sure, but it has 15-16 teeth. So one tooth would be 20+ degrees. Not likely to start.
Get a timing light on it and have the wife-assistant turn her over. See where you’re at.
edit. Crankshaft degrees vs camshaft degrees always confuses me.
Old 08-07-2018, 10:21 PM
944xjs's Avatar
ok yeah I’m borrowing a light tomorrow
Old 08-08-2018, 09:10 PM
944xjs's Avatar
Well hooked the timing light up and put a little shim in the throttle cap stand to keep the revs right under 1k rpm. If I let it try and idle by itself it wants to quit. So I got under it with the timing light and had a very hard time finding the timing marks on the pulley! Finally in the middle pulley saw 3 black slashes.... I assume that those are the marks? I hardly even noticed them unless I adjusted the timing light then they would move. Anyway... timing light was set at 10btdc... and that’s about where the middle mark was on the scale. So I assume either I didn’t plug a wire in all the way, the magnet isn’t set right or I have a vacuum leak. That wouldn’t make sense those cause it was idling fine before I put this distributor in.
Old 08-09-2018, 05:12 PM
944xjs's Avatar
Was I looking at the right thing? Shouldn’t there be actual etched in marks on the pulley?
Old 08-09-2018, 05:45 PM
Jagboi64's Avatar
From memory, there is only a TDC mark on the damper and the other marks are on a scale bolted to the engine. I may be off base on this though.
If it's running this poorly, you may have it off a tooth.
Old 08-09-2018, 09:38 PM
JigJag's Avatar
1986 HE timing marks.
TDC mark is on outer face of pully. Pointing at the belt.
Note this style of indicator is not adjustable in any way. Some apparently are.
Old 08-10-2018, 12:22 AM
944xjs's Avatar
Yeah I got the scale but where the heck is the mark? I didn’t see anything with the timing light on 1A...Is it on the outer pulley?
Ive never done timing on any car let alone a jag where you need 2 people to do it
Old 08-10-2018, 12:40 AM
944xjs's Avatar
Well I sure couldn’t see any marks like in this pic! Too much rust perhaps...
Old 08-10-2018, 05:38 AM
JigJag's Avatar
Hold a wire brush against the running pully and the mark should show up. Likely way off time.
Old 08-10-2018, 10:12 AM
944xjs's Avatar
sounds like a fun way to lose a hand. Ha
will give it a try
Old 08-10-2018, 12:22 PM
sidescrollin's Avatar
Is that not the mark at 29 deg in the picture?
Old 08-10-2018, 01:43 PM
Jagboi64's Avatar
That was my thought too.
Old 08-10-2018, 03:36 PM
944xjs's Avatar
yeah I think it might be, I took a brush to the pulley and hooked up the timing gun. I am wayyyyy off. Set to 10° btdc I can’t even see the mark, finally moving the degrees I found the mark. To get the thing to line up between 0-10 degrees the light was set to 60 btdc! Set to 40 it goes around that 25-30 mark. So ahh I guess I need to reposition the distributor and move over a tooth? cause it won’t have enough degrees to back off that much... this is all new to me so I want to make sure everything is correct. When I reposition the distributor.... I want to move it a tooth clockwise, correct?
Old 08-10-2018, 05:00 PM
baxtor's Avatar
kept in mind that the shaft will rotate as the distributor body is pushed into place.
Quick Reply: put in my new distributor... little help.
