Qtr. window motor
Qtr. window motor
Is anyone aware of where a set of brushes can be purchased for a 1994 XJS convertible rear quarter window motor? My passenger side window quit working, used the “tap with a hammer” idea, got it working. Decided to remove and clean the motor. Found it was dirty but the brushes were in pretty bad shape. Got it working but don’t know how long that will last. Any help will be greatly appreciated.
Timeisrelative (03-22-2020)
Found the thread. My plans are to ultimately control the qtr. windows independent of the top. Was real interested in how “Mac” wired his windows. Little different than how I intended on doing it.
Wiring is easy, straight forward, as I said the cabin is small, I had to remove the driver seat (US side). Short version, connect each motor +pos wire to each front window +power wire, @ the switch under the ski slop. Left motor wire to left ft window switch, same thing on the right motor to right ft window switch. Mount new rear window switches wherever you want.
I bought my switches & instruction of Paul Novak , from the forum . Anyway I still have it if your interested
Timeisrelative (03-23-2020)
