quad turbo XJS build
#101
Received 1,236 Likes
Timeisrelative (03-02-2020)
#103
Thanks for pointing that out to me. I'm not sure how I missed that he's trying to get the CR down to 6.5:1. Like you, I'm not sure the 6.0 pistons will do it, because I haven't seen one, but, it stands to reason that the wrist pin would be located higher on the 6.0 to accommodate the added stroke. However, at the time he shot the photos of the turbos in place, it appeared that nothing had been done inside the motor.
That clean motor was posted by someone else, and was used in a boat.
Yeah, it's common to feed one turbo from another. The point I was making is that you don't use that approach unless you are planning on big boost, and have a way to deal with the big heat which results from it. I can't imagine where he'll put a W-2-A intercooler that's big enough to cool that charge.
Even if he uses alcohol which has plenty of cooling properties. That engine won’t tolerate that much heat. Plus if you
FoolicooliXJ8
05-15-2012 01:09 PM
