Radiator Air Bleed port question
Next question guys: When I was bleeding the air out of the radiator, I loosened the bleed bolt on the top of the radiator after warm up and of course it blew off. Now I need a new one. Can anyone tell me the size of bolt and if theres anything special about it. I can't start the car until I get a replacement bolt.
I'm not sure if we are thinking of the same part, but I replaced that plug on my car with a radiator drain style petcock. I did that after replacing the radiator with an aftermarket unit though, so not sure if the size/threads would be the same. Petcock makes bleeding the air a lot easier.
