Radiator Caps
Not sure of the OE spec, never used them.
I dropped ALL my V12 cars, Series 6cyl cars to 13psi and used CPC caps.
I have even dropped the 2 S Type X200, and the X Type X400, to a lower KPA cap.
ZERO issues wiith any of them.
I have that spec/number somewhere in the stash in the shed, and sill go looking later in our day.
Found it, CPC 543/13.
Hi all. A bit of advice if you please. I want to replace both coolant caps. I hope to use a solid cap on the centre fill point and a 16psi on the expansion tank. Will the EAC3424 be ok for the centre fill or if not advice on an alternative would be much appreciated.
Rob.
Rob.
Grant Francis (01-05-2021)
chono
05-07-2018 11:10 AM
jaguarmarkv
Mark V - X 420G
06-16-2016 09:21 PM
