radiator condition
Clean first, see whether it falls apart or leaks, if it does its up to you, either buy new or repair this one. Mine was even worse than yours, but cleaned up perfectly and will still last me a while. On the other hand the AC condenser on my much newer x300 fallen apart and into multiple parts while simply lifting it from the car
Received 10,871 Likes
It looks pretty rough. And we're only seeing the outside. More often than not these 20-25-30 year old radiators simply need replacing.
But new radiators are expensive. Take it to a radiator repair shop. They'll disassemble it, acid dip it, and then be able to tell you what you've got. Sometimes all they need is a good cleaning, inside and out. Worth a try; you might get lucky..
The following 3 users liked this post by Greg in France:
Received 2,399 Likes
Don't know what clime Shahar's car lives in. So, I'm not sure if that is rust from the slush from the roadway or coolant leakage.
Either way, it sure does need at least a cleaning, at the very least.
It may survive a boil out and live a bit longer. But, if a rodding is needed, it;'s chances of surviving that brutal process is dim
I see the color of the fins and tubes as old black radiator paint.
Carl
Carl
The following 2 users liked this post by Ezrider:
Greg in France (09-10-2018),
orangeblossom (09-10-2018)
slmskrs
19
03-05-2023 09:59 AM
miatasportscar
31
10-10-2007 10:06 PM
10-28-2005 04:58 PM
