I would like to drain and replace the coolant. On my car ('85), there is a drain tap on the right hand side. See picture below.
I see the lever that is supposed to operate the drain tap. But I was not sure how to open it. The manual literally says the following: "Place a suitable receptacle beneath the radiator and open drain tap at right hand side." That's it.
I tried pushing the lever down. I tried pulling it up. Tried turning it. Does not go. At that point I decided to proceed cautiously and don't apply any more pressure fearing that it could result in irreversible damage.
So, how does one open the drain tap using the lever?
turn it. It can sometimes tighten up and may require a bit of force to turn.
Ok, thanks. I will try turning outward, with a little bit more force than before. (Next weekend, as I packed for today.)
Looking at the picture, the bottom plate (loaded by the spring) appears to be already at 45 degrees. Is it normal? Should I do another 45 degree turn? Or full 90?
The direction is correct, turn toward the outside fully. But first you should clean all the grease and gunk of from around the spigot, you could also use something like PB Blaster and soak the spigot a few times and let stand if needed overnight. that should or may loosen it up to turn, I also had to use a pair of pliers/vice grips (forget which one). If it doesn't feel like it is going to turn follow Grants advice on removing the lower hose. and don't forget to drain the overflow tank.
I concur. Just yank the whole thing out (it's surprisingly easy to do), take it to a competent radiator shop and have them weld in a simple valve.
It's also a good time to ditch the mechanically driven fan...and the sorry excuse for an electric fan...and replace it with some dual electrics. BUT...that wasn't your question :-)
I am sure I will get to e-fan questions soon. But I am not quite there yet. But I will get there eventually...
So, I sense some apprehension towards the "the tuxedo drain tap". Maybe I should go straight to lower radiator hose without even bothering with the drain tap? Don't want to end in a situation where excess pressure or some awkward move will require me pulling the whole radiator out to repair the damaged drain tap.
Are there success stories from folks who keep using the tuxedo drain tap to discharge coolant, time after time after time...?
Ok. Today I successfully (knock on wood) turned the drain tap and drained the coolant. (I first soaked it in WD40, after that it turned easily.)
Now that I have tried it, the name really fits, I think. It is indeed a tuxedo coolant drain type. Bond could do it while wearing a tuxedo (and making our with a girl, at the same time)
