Radio Antenna
Just to clarify, you don't an "1995 XJ-S Cab", you have an "1995 XJS Convertible". An XJ-S Cabriolet is a completely different earlier car.
The aerial originally fitted to your car was made by Hirschmann, Jaguar part number is LHB4120AA. If you have a rear spoiler fitted from new, the part number is LHB4120BA.
Ebay is your friend!
Good luck
Paul
Good luck
Paul
The following 2 users liked this post by ptjs1:
Greg in France (07-08-2023),
Mkii250 (07-10-2023)
Flint Ironstag (07-09-2023)
The cars with the rear spoiler have a special setup so that the boot/trunk lid wont open with the antenna up. LHB4120BA. is a faster up/down antenna that will retract when the trunk lid opens to stop getting broken by the spoiler. SO really you need to find 1 of those as it will fit as a direct replacement and use the existing wiring plug. Look for a '95 '96 scrap car.
Second option is LHB4120AA will fit the wiring but i believe will not retract as fast.
The older antenna will have different plugs .....And will most probably you will forget that is up and open the lid.
