Radius arm bushes - time to replace?
When my oil was changed, I took the opportunity to give the underside of the car a good look while she was up on the lift. Seems to me that the radius arm bushes need changing. Or is this just the normal state of a used bush and not something I need to worry about? Is any cracking in a bush a Bad Sign?
Somehow I suspect it's not good, and they could do with replacement. The shiny new wires on the large bushes make me think they were replaced recently, but I'm pretty sure it wasn't under my ownership. Though the radius arms themselves were checked in her big inspection back in Dec. 2017 and found to be fine. Radius arms with bushes added can be bought as sets, but if the arms are fine, perhaps just the Bushes, Senior and Junior.
Right small bush
Left small bush
Left large bush
Right large bush
Right small bush
Left small bush
Left large bush
Right large bush
MY opinion:
They are showing wear, that would be normal.
Those cracks are not terminal, OK, no one likes to see cracks in bushes, but they are minimal.
I would NOT go the bush only route, UNLESS your shop has the equipment and mindset, to replace them without distorting the arms. The Big bush is the main culprit. Those arms will distort in less than a heartbeat if great care is not used, mainly at the "pushing in": stage.
I got the pre installed arms every time, and it just sat well with me.
AGAIN, they are not bad, some of mine went for years with more "cracks" than that.
It gets back to the "while I am getting stuff shipped" scenario again.
My shed is FULL of those items, oh dear.
The following 3 users liked this post by Grant Francis:
The following 2 users liked this post by VancouverXJ6:
Grant Francis (06-18-2020),
Some Day, Some Day (06-17-2020)
While definitely ageing, it doesn't look too bad yet. I'd keep it in the back of your mind as needing to be done but not urgently. Call it deferrable maintenance. Maybe before the next Shaken if that's a fail as it stands now? The wire is stainless, so that's why it's shiny.
Depending on what your shop charges, it may end up cheaper to buy new arms with the bushes already in place than replacing the old ones. It's not difficult to change them, you just need a hydraulic press and some properly shaped metal rings to press on the bush and not the arm. If it's a Jaguar specialist I'm sure they have the tools already. Although freight on new arms wouldn't be cheap...
This is one place where you should only use the original Metalistic bushes, nothing aftermarket. If you want a firmer mounted IRS that will make it a bit harder, you can go to solid poly bushes on the small end only. Also on the big end turn the bush 90 degrees, so the pair of holes are across the car, not along it. That makes them around 20% stiffer.
The following 4 users liked this post by Jagboi64:
Greg in France (06-18-2020),
smgdata (06-18-2020),
Thanks for all your comments and advice. This is exactly why I post on this forum - I'd have panicked, thinking they're about to rip asunder. The wisdom of the sages is much appreciated.
I've heard about the benefits of replacing the entire arm and how hard it is to get the bushes out (Hmm. Bill Clinton managed it...). The next shaken (MOT/WOF whatever you call it) is next month, but I don't think it'll be a problem, not if it's not that bad. I'll talk to the mechanic then about whether they can easily push in the new bushes or whether the whole arm would be preferable.
I don't have a shed, let along a shed with room for "eventually, when it fails" so I'll hold off on ordering I think. Freight on the arms couldn't be too much worse than on other heavy things like brake discs or four shock absorbers.
I definitely do not want a firmer ride. She's already rather firmer than I was expecting. I'll stick with the metalastic, no aftermarket if possible. JagBoi - I've read a few posts and that by people who've done the 90-degree route, which apparently is what Jaguar Sports did. One guy described his car as now "bunny-hopping" across the road. That would not be the ideal "Jaguar ride" I feel.
The following 2 users liked this post by Some Day, Some Day:
I will just add that I did do full Poly on both, and ended up tearing the mounting peg the large bush sits in, though PARTLY due to a prior shitty weld.
Third time's the charm I guess. Definately did not bunny hop more of a F-35 Fighter jet darting maneuverability, which of course strained the structural integrity. I'm back to OEM large bushings poly on the small end its a good balance if aiming to retain Jaguarness
Some Day, Some Day (06-18-2020)
Yes, Metalastik is the OEM supplier, I think a brand made by Dunlop, the bushes have the small D logo on them. In my experience, they are by far the best makers of rubber bonded steel products and outlast all others.
A further thought, the arms are often replaced because many cars are driven in wet/salted roads and the arms rust from the inside out. By the time the rubber bushes have deteriorated, so have the arms. Your arms appear in amazingly good shape, so that condition doesn't apply to you.
Yes, Japan doesn't use salt on the roads. They do use a snow-melting thing on certain roads which doesn't do wonders for steel, but I don't drive her in the snow. I do drive her in the wet, of course.
Huh. Didn't realise "Metalastik" was a brand name.
In terms of their orientation affecting the ride, I was going by this post in particular:
The discussion there is whether the increased stiffness simply transfers the stresses to the frame mounts.
Greg (in France, not any of the other fake Gregs in other countries) also comments that
One time I was changing the large radius arm bush, I decided to do what Jaguar Sport (I was told) did, which was to put the bushes in so the slots in the bush were at the sides, rather than fore and aft as is the original factory way. This in the hope of tightening up the rear handling a bit. Complete disaster as the car ‘bunny hopped’ on the straights over undetectable small irregularities in the road surface. I presumed that the reduced compliance meant that the cage moved rather jerkily or the arms moved less smoothly. Took them out and changed to normal fore and aft and problem disappeared.
I found that a great deal depends upon the tyres, spring rate and damper settings. I tried this on my non-sportpack car, and it produced a very distinct and noticeable - by the Management no less - "bunny hop" to the rear end on some very good main road surfaces at about 50 to 60 MPH. No apparent cause from the road surface, So I took them off and turned them back to holes fore and aft and all back to the legendary velvet on cream ride.
Wouldn't foam just hold water and get soggy and rust things even worse?
I actually try to drive my car soon after she's been rained on (which is often) in order to shake loose any pooled water and dry her off through a combination of heat and wind.
They are hollow because solid ones would weigh a ton. A coating of cavity wax inside and outside the new ones will preserve them.
I just did mine last weekend.
right side I did with the uro ones prob a year ago. and the left had metalastik prob the originals. now the uro have delaminated on the small bush, and my metalastik one has seen better days but is still together, 35 years +/- I grabbed the metalastik ones from sng, they did differentiate between the brands as of 2 months ago but today I looked and they do but don't say "metalastik".
Let me tell you I noticed a huge difference.
Grant Francis (06-19-2020)
JagsteRJX
12-31-2016 12:07 PM
