Radius arm not lining up
I half-tried that and the inner ring in the large bushing was making solid contact with the mount, so much so that it wouldn't slip, but just distorted the rubber until I lifted the car back up. I was afraid to put any more weight on it.
Hi MrAndersonGCC
I had exactly the same problem when refitting the Cage to '50 Shades' my Grey XJS
Basically what I did was to Chock the Front Wheels, so that She couldn't Roll Forward and then I put the Back Wheel on the side where the Trailing Arm wouldn't go back and then put a Chock under the Back Wheel
Not right in the middle but a little bit Aft of the Middle of the Tyre, where the Plan was to lower the Jack down so the Back wheel would try and Roll Forward and in doing so move the Trailing arm Forward
Except I never got around to lowering the Wheel down that evening (maybe it was too dark to see what I was doing) so I decided to leave it until the Following day but during the Night the Jack lost pressure and went down on its own!
Where to my Amazement it was Perfectly Lined Up!
You can read all about the Sorry Saga Here: Trailing Arm Wouldn't go back! Jaguar Gods To The Rescue!
Greg in France (04-07-2022)
Received 9,213 Likes
