radius arms
New to forum and I have purchased a 94 xjs convertible that needs a little work. I am removing the radius arms off the rear suspension. The bolt that holds the radius arm to the rear axle does not clear the shock mount in order to remove the radius arm. There must be an easy solution but I don't know it.Please help.
Hi Dom and welcome. That bolt should have one corner of the bolt head ground off. Line up the ground part and it should JUST clear the mount. Good luck and let us know how you make out.
As an aside, mine was so rusted inside the bushing I had to cut it out.
Camnelson324
09-27-2015 08:48 AM
