Rattle - exhaust mounting bush or exhaust system
Greetings everyone,
Trying to isolate a rattle in the back that is noticeable when: a) turning corner; b) going over bumps. My first thought was exhaust mounting bushes but some underside photos of corrosion on exhaust system make me wonder if it is corrosion related to silencer and immediate exhaust silencer, clamps, olives, sealing rings? See photos 1 and 2. AND, just to confirm, is the circled part in photo 3 a CC? Many thanks,
Charles
Charles
Charles, it is any or all of the following:
- over-axle pipes hitting the cage, including the support pin at the top inside of the cage/pipe support having failed or its insulator/rubber having failed
- exhaust resonator boxes in the tunnel hitting the sides/support rubbers in the bracket failing
- under-seat main silencer boxes hitting the body
Grant Francis (05-05-2021)
Dear Greg,
Thank you a million! Oddly enough, the clank, clank, clank only occurs on right-hand turns and round abouts (apart from bumps).
Just to clarify (with a diagram) . . .
a. over-axel pipes are #8 and #7 in the diagram
b. under-seat silencers are #1 and #2 in diagram
c. exhaust resonator boxes #13???
Yes, all correct. If you have catalysts, which I do not, then check with Bell, but I think that you will only need stainless downstream of them (ie NOT downpipes - contrary to my PM) as the cats part of the exhaust (at least on the one I had to help a mate dis-assemble) is made out of an incredibly high quality specialised steel.
Greg in France (05-05-2021)
98intrigue
08-05-2016 03:29 PM
