Read wheel stud for alloy starfish wheels
My '87 XJ-S has lost a rear wheel stud (along with the lug nut of course).
In shopping around for a replacement, many of the ads specify that their product is for "steel wheels", while other ads don't say one way or the other. From looking at the photos they look like the same part.
I have the alloy starfish wheels. Is there a specific stud for my wheels?
I'm only missing one. Is the vehicle safe to drive?
Thanks,
John
1987 XJ-S V12
Thanks,
John
1987 XJ-S V12
Lucielle (10-21-2021)
Thanks,
John
1987 XJ-S V12
Thanks,
John
1987 XJ-S V12
Also remember at the same time I read that they were different they also were discontinued new so used was only avenue for purchase.
I may be wrong on both since that was 15-16 years ago
The wheelstud is steel and as long as the new one is the same dimensions as the others it is the same for all wheels. You should not drive the car until the fifth stud is in place; but if it were me, I would replace them all on that hub. Wheelstud normally fail only if some rock ape with a rattle gun has done them up far too tight. The XJS wheel nuts should be done up to 75 ft llbs, and no tighter.
Received 10,916 Likes
My quick research in the Jaguar catalog shows C13365 for your XJS, with no mention of steel vs alloy wheel
https://shop.everydayxj.com/XJ6_XJ12...g06-c13365.htm
davidboger (03-22-2020)
The following 3 users liked this post by J_C_R:
