Rear bearing failure
Old 08-23-2020 | 06:31 PM
VancouverXJ6's Avatar
Default Rear bearing failure
My other rear bearing has failed, the last time (other side) the shop tried everything...heat cold hammers presses and even sent it to a machine shop with a 100 ton press they ended up crushing the stub axle thing trying to push it out as nothing else would work. The Jag shop's 20ton press did nothing.
Is there anything I can do to loosen it up prior to returning the car when the bearings arrive?
Just for context this is why my car is hobbling and grinding down the road to the point of being undrivable.
Old 08-23-2020 | 07:26 PM
v8deuce's Avatar
Strange they have so much trouble with it,I used heat in my shop and even the tough one came loose.I don't know of anything that you could do to loosen it before replacement
Randy
Old 08-23-2020 | 08:52 PM
Jagboi64's Avatar
Do you mean they couldn't get the halfshaft out of the stub axle, or couldn't get the bearing races out of the hub carrier?
Old 08-23-2020 | 09:20 PM
Couldnt get the shaft out, I wondered if baking it in an oven would work lol...I'd rather not repeat last time which ended in buying a whole 'new' unit from a less neglected car.
Old 08-23-2020 | 09:57 PM
Jagboi64's Avatar
I wonder if someone previously used loctite on the shafts? Heating to 400F will break the bond. Either that or they rusted in place.
Old 08-24-2020 | 12:23 AM
Greg in France's Avatar
Mine took a 40 tonne press with a thumping action, it could easily have been impossible, as not much more than that will break the ally hub carrier.
Johnken
05-28-2020 09:58 AM
Johnken
02-26-2018 10:01 PM
liquidreality
09-09-2014 08:08 PM
David's XKR
08-15-2012 08:00 AM
JagScott
11-28-2010 06:51 PM
Quick Reply: Rear bearing failure
