Rear brake parts advice, please.
Finally have gotten around to ordering the pads and rotors for the rear brakes of my 1992 5.3 litre v12 XjS, Vin # SAJNW5847NC181646.
Just a few questions to make sure that I'm not ordering the wrong parts...
1) I've gone ahead and ordered two of these rotors.
Centric Parts 121.20008 Rear Disc Brake Rotor | eBay
Description shows they fit a 1992 XJS 5.3, no notes on chassis numbers. Hopefully, I am assuming that these will fit.
2) Haven't pulled the trigger yet...will shortly on these pads:
CENTRIC 102.00090 Brake Pad or Shoe, Rear | eBay
Description is the same as above, no notes on chassis numbers.
3) Saw these shims:
BECK ARNLEY 084-2053 Rear Brake Pad Shim | eBay
Description shows they fit from CU (guessing that means chassis number?) 188105. Since the last digits of my vin are 181646 (which I am once again assuming is the chassis number) that these do not apply to my application. Will I be needing shims for this job or will whatever is installed at present work? An ebay search only shows shims with the same Beck-Arnley part number, no other part numbers for other shims that may work.
Thanks for the help,
howlinowl
3) Saw these shims:
howlinowl
Just noticed in the graphic for the brake pads that they use shim kit 115-00063. Did an ebay search and came up with this:
CENTRIC 115.00063 Brake Pad or Shoe, Rear | eBay
The description states that it does not fit my 1992 XJS.
howlinowl
howlinowl
Received 10,873 Likes
If your car has the old inboard brakes (and, as a '92, it should) those look like the correct parts.
Oddly, going to the Jaguar/JHD webpage your car (181646) shows having outboard rear brakes. Weird. But, not the first time weird things have happened with parts listings
3) Saw these shims:
FWIW, I've never seen pad shims on the "inboard rear brake" cars....although some brakes pads come with shims anyway,as anti-squeel devices.
howlinowl
howlinowl
Lots of incorrect, confusing, or misleading info out there with these on-line parts catalogs. Usually, if shims are needed, they come with the pads.
Doing the rear rotors it is far easier to drop the rear end - it is only 12 bolts and the tailshaft bolts. Clamp off the brake hose with haemostats so bleeding is easier and the handbrake cable.
The headache is the calliper bolts these are almost inaccessible. And I would hate to have to install the security wire while the rear is in the car.
Greg, as with most Jaguar repair work it was cheap! Ted billed me $1,400 for labour and parts with the exception of the rear rotors and all 4 pads which I supplied since I wanted those specific brands. He said they have many "tiny, specific" wrenches to do the work without completely dropping the rear end. The restoration section of the shop is like a toy store with e-types, 140's, 150's and a 330 so I figure they know their trade.
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
