rear brakes and rotor replacement ?
I just ordered aftermarket rear brakes and rotors for my 1993 xjs inboard brakes. I ordered them from a jag. speciality shop and they stated they will work fine and were reasonably priced. I then contact a local jag. speciality shop locally about some else and we got onto the subject of my rear brake rebuild and they stated that you must use original jaguar brakes and rotors or you will have overheating problems.
All I'm trying to do is to get my car back on the road in a safe and reliable way without spending a mortgage payment to do it. I figure original equipment might be better, but will new after market from a jag. distributor work.
Does anyone know for sure that jaguar brakes MUST be used or can a good set of aftermarket brakes do the job. The inboard brakes on my 93 xjs are a pain to get to and replace, so I really want to only do this major job once as far as rotors are concerned, the pads I know will have to be replaced down the road.
Received 10,914 Likes
BrentGardner
28
04-26-2024 03:08 AM
