Rear disk brake retrofit?
Is it possible to retrofit the vented brakes from a 99 XJ8? I know the callipers will be different, but assuming I can get everything from the XJ8, will the bracket bolt up to the XJS hub?
Is there a difference in the piston diameter than will affect the front-rear balance?
I also run a set of 15" rims, would the XJ8 brakes clear a 15" rim?
I'm planning an IRS overhaul for my Daimler DS420, and an outboard brake conversion is in the works. I've already figured out the necessary parts for the halfshafts and hubs that are different, looking at braking options now.
I can answer part of my own question. I have a 1995 XJR hub in the garage and it wouldn't fit in a 15" Kent rim. The 99 XJ8 disk is the same diameter as the 1995 XJR, just vented. So much for the bigger brakes idea!
I believe the XJ40 brakes and hubs can be retrofitted though to give outboard brakes.
Hi,
I purchased a later outboard IRS which I used for updating my 92 XJR-S. During that swap I replaced the rear outboard brakes\hubs with those from a 99 XJR. Bolted straight on. Two issues to be aware of, I needed to make a spacer for the drive shafts otherwise there was excessive camber on the rear wheels, and secondly getting the ABS working\functioning properly was a labour of love!!
Need to be mindful that I was after larger vented disks on the rear, and I have 17" revolver XJR wheels on my car which were needed to clear the disks\calipers.
Beavis.
x308 XJR hubs and disks during install on my XJR-S
Disks just showing through revolvers...
Beavis.
Later xjs post 93 (actually made from mid 1993) had outboard rear discs, early model 6.0 had solid rear discs, from 94 or 95 they went to vented rear discs, I believe these can be retrofitted to earlier models with outboard rear discs, but you would require discs, pads and rear brake calipers.
Hi,
Beavis.
Beavis.
Just a side note, they aren't revolver rims but sport rims from the XJR6 (X300)... The revolver rims are these here and were introduced with the X100 XK8:
