Rear shock/tow link nut size
Does anyone know the size of the nut that holds onto the bottom of the rear shocks? I came up with part # NY607041J but this wasn't in a diagram, so I wasn't sure.
Typically searching part numbers eventually leads me to a site that will actually give specifications, but no dice this time. Thanks
These are the nuts holding the rod the shocks are attached to I think? For some unknown reason one end has an 11/16ths A/F nut and the other has a 5/8ths A/F. As I expect you already know, the rod can be withdrawn forwards only, as the bracer plate thingy on the rear end has a hole too small for the rod to be driven out rearwards. The actual threads each end of the rod are identical and have UNF threads.
Greg
Greg
sidescrollin (01-08-2018)
LeapingCat
Mark V - X 420G
02-22-2014 12:39 PM
H20boy
General Tech Help
10-31-2010 08:27 PM
