rear tires turning in neutral
on my XJS V 12 Is there a way to "adjust" the transmission to stop the rear wheels from turning in neutral.... I can stop them in Park but in neutral, they run a bit although I can stop them with my hands, when I release, they start back..... When I am at a stop, I normally have to have my brake on unless I am uphill...
Thanks.
Thanks.
sidescrollin (01-16-2015)
Received 10,872 Likes
Received 6,327 Likes
you are in drive at a stop in normal driving conditions ,not neutral. The car will drive forward on the flat, or maybe roll back on an uphill, all depends on your idle speed. If you speed up your idle it won't roll back on uphill, but will use more fuel and try to drive forward faster on the flat.
If you slow the idle it will roll back on uphill stops but may not drive forward on the flat, but you will more than likely have rough idle.
The factory recommended idle speed is probably the best balance you will get.
If you are in neutral on axel stands the wheels will spin with engine running, but you can stop them with your hands. If you put it in park the wheels won't spin.
Best bet is to stick a foot on the brake when you are stopped. Every automatic car I have owned has been slightly different.
I'm sorry, but you make it seem like you put your car in neutral at every stop? Why?Or is it in drive? In which case it will always creep forward some and you will need to keep the brake applied at stops
Way too much into this...... Just a question as I thought it was weird that in neutral, with wheels off ground, the rear wheels spin slowly. The answer was that this was "normal" and I was satisfied with that..... Just curious !!! Perhaps I did not explain my question clearly enough !!!! Thanks for all the responses.... No more necessary !!! lol.....
Received 2,263 Likes
Daim (01-17-2015)
philwarner
09-05-2015 10:05 AM
innzane
09-02-2015 10:08 AM
