Rear toe in
How badly is it out of spec? The rear toe is not adjustable. Because the lower wishbone inner fulcrums are fixed in relation to each other, pulling one side forward or back somehow, will also change the other.
Once you let us know the size of the problem, it might be something as simple as running in unforgiving new large radius arm bushes.
Rex
The final line of the print out is the rear toe. Both sides are in spec and 0.07 of a degree difference is WELL within the measurement accuracy and repeatabilty tolerance range of the equipment. Your rear toe is PERFECT.
As is, I might add the rear negative camber, whatever the red part says!
You have been fed pure moonbeams (ie BS).
Drive it, enjoy it.
Drive it, enjoy it.
The following 3 users liked this post by Greg in France:
Greg in France (08-10-2021)
But of course, as you say, the dog bone shims and bolts cannot be changed or tightened or undone without completely disassembling the lot.
The inner fulcrum pins are firmly located into the cradle itself.
The "dogbones" position the diff unit lower mounting.
Unless the heavy pin washers welded into the cradle come adrift, those inner pins, and the inner fulcrum eye (with needle rollers), is in a fixed position.
Wear, obviously, will allow things to flop around. Missing shims, loose dogbone bolts, basically allows the diff unit to "clunk around", being the noise often heard when moving from R to D and back again.
None of my inboard brake cars have ever had those dogbone bolts tight, from way back in the MK X days.
