Rear wheel alignment
I hate to eat up everyone's time with my silly questions, but you guys are so saavy and smart about my impossibly Britishly engineered car I can't help myself!
I have major toe-out on my rear wheels. Since it doesn't seem possible to adjust rear wheel toe in/out, am I correct in assuming something is probably bent? FYI, the car was hit in the right rear quarter panel, if that can matter (repair by previous owner).
Thanks!
Thanks!
Received 10,920 Likes
Thanks!
Thanks!
Yes, no toe adjustment on rear wheels, Yes, probably something bent. Or perhaps some badly worn or loose control arm and/or fulcrum bearings allowing the wheels to splay out?
PS- there is nothing "impossibly engineered" on a Jaguar. Anything that has the appearance of being poorly or impossibly engineered is actually an "interesting design feature" that you simply haven't yet learned to appreciate.
Owning an old Jag requires a philosophic frame of mind :-)
The following 2 users liked this post by Doug:
Michael Hop (07-23-2019),
rgp (09-30-2017)
Doug, once again you are the man. I'll check my bearings and bushings. They're all pretty worn.
My apologies. I amend; my fascinatingly engineered Jag
I actually had my rear wheel bearings replaced. I removed the hub assemblies myself, and I'm close to certain that I put the correct hubs back on the correct side. But if I somehow reversed them, put driv on pass side and vise versa, could that cause them to be splayed, or are they not specific to a side?
rear wheels going bald on inside.
Thanks!
Thanks!
- far too much negative camber, or
- massively unaligned rears that are toe-ing OUT [correction] miles out of spec.
Camber can be adjusted; toe OUT miles out of spec = something bent or very badly worn or dangerously loose. Non OEM springs never a good idea IMO, but unless the ride height they give is miles out of spec should not in themselves give tyre wear; unless this "conversion kit" is something more than just replacement springs.
Greg
When you did the hubs did you check end float, this is set with a spacer in the back of the inside bearing, if this is not correct there will be excessive play in the bearing. If you are checking on the ground with a string line then wheels will tend to toe out as the car is moved forward.
Greg in France (07-14-2017)
Bad inside tyre wear on the rears is either:
Greg
Greg
Greg
i also noticed this was quite an old thread so maybe time to wrap it up! however I'm thinking it could be tracking rod that's my problem but not sure yet my pal is going to jack it up and have a good look next week
hunter34
19
09-14-2022 11:09 PM
innzane
09-02-2015 10:08 AM
