rear window switch xjs convert
Here's a 700+ page manual for all XJ-S. I skimmed the window part a bit, is there a button in your car for the convertible. I believe the rear windows roll down when you press the roof button, that's what I gathered from skimming.
http://www.jag-lovers.org/xj-s/book/Xjs_help.pdf
Also, this would probably make a good FAQ, jim or Big.
Doesn't sound like it. JW, look at my previous post. The side windows, the rear quarter glass windows, move with the top. Any time the top comes down, these go down with it. There is no separate button for them. If you want to lower those windows and not the top, no problem. Just leave the top latched and press the top button. The top won't move, but the windows will. This does not hurt the top motor, it's designed to do this. If you windows don't move, you probably have bad motors. Very common and very expensive.
Guest
Posts: n/a
I just came across your posting about the xjs rear window switch. The rear windows on a convertible are called quarter windows; they are not operated seperately; when opening the conv. top, they move to an open position automatically; and then when closing the top, they will closeas well.
hope that helps.
hope that helps.
