Rebuilding Rack and Pinion
Hello fellow XJSers,
Today I am coming to you with two questions. A little backstory first, though. Recently saw power steering fluid leaking on Morris, changed the power steering hoses as they were old, possibly leaking, and I had access due to the water pump being changed. The leaking stopped, up until about two weeks ago, when it power steering started leaking again. At first I thought it was the hoses, and that maybe I had bolted them in wrong (those fine threads, argh!). Nope, I removed one of the boots and lots of power steering fluid came out, so the rack seals have gone bad.
First question: How hard is it to rebuild the rack and pinion? XKs Unlimited has a kit to rebuild it. Taking it off is no problem, done it once already, and I'm pretty mechanically inclined (changed water pump, valve cover gaskets, etc.). I've never done a rack and pinion before, though, but I figure someone with a Master's degree should be able to figure it out, right?
Second question: assuming it sounds doable by me, how many of you would be interested in seeing me rebuild it? Maybe pictures, video, etc.?
LnrB (05-21-2014)
Woznaldo
09-26-2015 11:02 AM
